How to rebuild Odyssey JC Pedals
[LEFT]Wow. I owe you both a beer.
I really think the massive amount of grease did the trick, but Iâm willing to concede that fussing around with the proper torque on the inner nut certainly helped.
There seems to be a sweet spot there that is very difficult to measure, however the slop disappeared even before I put the nut back on, thanks to the excessive grease.
For those that follow (and use the search feature):
The Pedal:
Quickly clean the pedal. You donât want any dirt falling back into your clean bearing work before you seal everything back up. Remove the plastic dust cap from the outside edge of the pedal using a screwdriver or small blade.
Place a pedal crank on the spindle (threaded - see first image) end, and a 12mm socket wrench on the outer nut exposed from the removal of the dust cap. Remove the nut (visible below).
Firmly tap the pedal on your workbench to remove the washer.
Before doing this step, ensure you are working over an enclosed space, like a can, or shoebox. Remove the inner nut (visible above) by again using the pedal crank on the spindle end and a 14mm or 15mm socket on the inner nut. Be careful, the bearings are exposed at this point:
While securing the spindle, tap out the bearings into your can or shoebox. Count the bearings, there should be 13. Remove the spindle, exposing the bearings on the opposite side, and tap those bearings into the box. Count the lower bearings, they will be smaller, and there will be 18 of them. Degrease and clean the bearings. Clean the inside of the pedal and the spindle. Using some grease and a small screwdriver blade, reseat the lower 18 (smaller) bearings. Load the spindle up with grease and reinsert into the pedal.
Reseat the upper (larger) bearings, and throw on more grease.
This is the tricky part.
Place the inner nut back on the spindle. Tighten. Does the crank end still spin freely? If not, youâve overtightened. Loosen the nut 1/8th of a turn and try again. Repeat until the spindle end spins freely, but the pedal does not have any play against the spindle. This may take several attempts, but is worth the effort as it rewards you with a solid pedal. Place the washer back on, place the outer nut on the end, tighten, and pop the dust cap back on.
Done.
[/LEFT]
