I planed on riding my 6’ through the parade(in the past now) but I took the pedals off and then put them back on. Their is no tenshion when puting the pedals in till the end. but I think my cranks are bent. I barly got it.
I learned how to freemount(its so fun) and a few days later this happens. And even climing onto my deck to get on it still feels odd to ride. I attemt to freemount but it wont let me.
Your post was hard to read. Did the pedals not screw on tight enough? Is the chain still on the right-hand side?
If your cranks are bent, you should be able to see it if you look from the right angles. If there’s not enough to be able to see, it’s probably not enough bend to worry about.
How would the cranks have gotten bent?
BTW, if you are a relatively new giraffe rider, it never “lets you” mount it. You have to fool it! With more practice it gets easier to fool.
thanks but it has never felt like this before my frame is like a upside down Y so I cant check right angles. I could ride it ( after I fooled it) then it (fooled me) and I cant ride any more all in the same week?
I’ve done it If you put them on the wrong side they won’t go in straight and will make the crank(s) feel bent.
Check and make sure everything is on the right (or left :D) side.
Yes thats right I fooled my unicycle again. I figured no one knows whats wrong(probly just the unicyle tricking my mind) I would have to get used to it. I have freemounted it and even told my boss’s sister that I can do it. Good to see the reacation.
