I have a Torker CX 24", and lately, when I’ve been pedaling, or hopping, it creaks…
Will lube help, or is it just because its not a very good uni, and it just can’t take everything that I do to it (hopping up and down curbs, a lot)
What should I do?
It might just be that the spokes are loose. That’s what was wrong with mine. It doesn’t seem to be that big of a deal just annoying. Try and hear where the noise is coming from because there’s a lot of stuff that can creak on a unicycle.
Be sure your crank bolts are tight too, and that your bearing holders aren’t overtightened.
Check your reflectors on your pedal, the get loose very easily and decive your ears!!!
