I rode RAGBRAI this year with my muni strapped on top of my BOB Trailer. I recieved a lot of comments about having a spare wheel for my bike on the trailer. I don’t think people realized what they were seeing. Must have been the heat, or the beer
now all you need to do is attach a bob trailer to a coker and you’d have the perfect getting to unicycle conventions vehicle. Anyone pulled a trailer with a uni?
I’m loving the picts of people using trailers to carry their uni.
Has anyone thought of using their uni as a trailer? I mean it alredy has a wheel and fork. You could try removing the seat and post and using some tubing the same size and have it connect to the seat post of your bike.
Just my thoughts.
One problem i see is wheel wobble caused by the weight of the unicycle pedals.
I made a slight alteration… I don’t know how you secured the frame of the uni but I couldn’t find a way to stop it swaying from side to side due to the weight of the seat. To this end I removed the seat (a minute’s work with an allen key) and tied that on behind the bike seat. Not only does it stick out less but the frame can be tied to the seatpost so stop any movement at all.
No comments while riding to York and back, but plenty of stares…
I used two bungee cords, and they went in and under the rack, cranks, and on either side of the frame seatpost holder. This kept the seat from swinging.
After undoing one bungee, it was loose enough to twist the uni forward, and walk beside my bike (uni saddle near the top tube) and hold it in place with my body weight and position. This helped in getting it into the elevator (that’s Canuck for ‘lift’) abd out the 2 sets of doors of the apartment (flat) 's main lobby.
After undoing one bungee, it was loose enough to twist the uni forward, and walk beside my bike (uni saddle near the top tube) and hold it in place with my body weight and position. This helped in getting it into the elevator (that’s Canuck for ‘lift’) and out the 2 sets of doors of the apartment (flat) 's main lobby.
> from swinging.
Heh… I used four!
One held the front of the wheel tightly to where the bike seatpost meets
the frame, one held the uni frame to the bike rack; one held the
downward pedal in place and the last held the uni frame from swinging
back and forth.
Possibly overkill, but it was absolutely rock solid… that uni was
going NOWHERE! Near where I live there are several really nasty
speedbumps put there to gouge holes in the bottom of cars. It didn’t
even wobble…
(Own up! What’s being slashdotted?)
Phil, just me
Cattle Prods solve most of life’s little problems. For everything else,
there’s a small plastic penguin…
