Hi, I am hoping to buy a new unicycle. I’m going to do some trials and some street. I need a unicycle that could take jumping off park benches and doing unispins. I am thinking either a Bedford lightduty trials or a nimbus trials. I don’t know anything about the Bedford so I’m not sure how good it is. The nimbus sounds good except the hub, but I believe it now comes with a splined hub. http://www.municycle.ca/signature-distroyer-nimbus-trials-19-isis-p-487.html, that’s the unicycle, and I believe that this is the hub http://www.municycle.ca/nimbus-isis-hub-36-hole-p-174.html. I would order it with 137 mm kh moments. How would that compare to a Bedford? The lightduty is $250, how much might it cost with all the components that the nimbus has? By the way although I’d like a kris holm I can not afford it so it is not an option.
If you want cheap ISIS then go nimbus, if your just beginning, the bedford light duty is great. if you plan on doing a bit more and have the money bedford heavy duty all the way
Okay thanks. I am already pushing what I want to spend so I don’t really think I can get the heavy duty, but just for interest how much better is it? And how much does it cost? The pricelist says $420.
Bedford’s pricelist is super old. You should call him or email him to get a better idea of what he can get you and for what price. Darren is a great guy and should be able to get you set up with anything you need.
