I am selling a complete hand built 29" Oregon wheel:
Nimbus Oregon 36h hub, 125mm bearing spacing, green and black
Nimbus Dominator 2, 29" x 42mm rim, black
14ga straight gauge spoke, black
Brass nips, black
Stans’ rim taped, tubeless ready
This wheel can be purchased with a barely used Surly Knard 29" x 3", 120tpi tire. The Knard is the fattest 29er tire made, the 120tpi version is ~900gms, with a super supple, high volume casing. The Knard is fatter and has more volume than a Wildlife Leopard!
I also have a Bengal disc brake, 160mm rotor, that could be worked into the deal. If you don’t have an Oregon frame, but you have a Nimbus muni, all you need to upgrade to an Oregon is this wheelset and an Oregon frame…
Note that this wheel will only fit in a frame that is built with a 125mm bearing width, which is limited to the Nimbus Oregon or a custom built frame.
Looking for best offer, with preference given to someone interested in purchasing the wheel and tire together.
PM to discuss details.
