Nimbus Oracle 36"
Due to some changes in lifestyle I’m looking to sell my 36er. Solid machine with a bunch of after market add ons. Only light cosmetic damage from some light muni.
Here are the items the previous owner changed/upgraded from stock:
-Blackspire Sub4 pedals, green. Made in Canada.
-Kris Holm Spirit dual hole cranks, 127mm/150mm.
-Vee Rubber aka “The Todd” tire, about 50% tread remaining.
-Kris Holm Fusion Freeride saddle.
-Hydraulic brake line has been shortened to be more direct with less slack.
-The Nimbus seat post is exactly 8 inches in length.
Full disclosure: Previous owner had issues in the past with significant brake squeal and vibration but it is not exhibiting that now. It was serviced last year before I stopped riding and has been stored inside since then.
Price: $600 plus shipping anywhere in the 48 states or local pickup. Shipping to be calculated. Near Worcester, MA. Reasonable offers considered.
I’ve got the same Oracle 36 (with the same brake ‘tektro auriga sub’) and I also had the same squeal/vibration issue from day one. It is not a big problem - quick and easy fix: I replaced the pad that originally came with the Oracle with a ‘Clarks Organic disc brake’ and hasn’t squealed since (the Clarks organic pad works really well and it lasts for a long time before it needs replacing again). Great unicycle for road riding :slight_smile:
Check your PMs
If the ad is still up its still available!
Re:
I think that every Oracle owner has the same vibration issue, this is the main problem of this device.
