I wanted to get a 24’ uni and I can’t decide between the Torker DX or the Nimbus X, I’m leaning towards the Nimbus because it is a little bit cheaper.
The main things I want is one that is lightweight, and be good for doing some off road stuff, so if you think one is better than the other please post.
I may not be the best person to ask, because I am real new at this, but …
I have a Nimbus 2 – which is the street uni with the hookworm tire as well as a Torker DX. The Nimbus 2 is a very smooth ride and a clear favorite on the street.
If you want to ride off road, I would definitely go with the 3 inch tire that comes with the Nimbus X.
My first try at MUni was the Louisville meet about a month ago on the Torker DX. (I walked a lot and I think both are probably equally easy to push) But, when I got home I bought a MUni with the Wildlife 3 inch tire and it is a whole bunch easier to ride than the Torker DX.
The narrower K-Rad tire on the DX didn’t ride very well when I tried to deflate it for the trails.
Really, you have to make a choice between the 10 splines on the DX or the 3 inch tire on the Nimbus X. I would go with the tire, because it’s easier (and more fun) to ride. When it breaks fix it or get another one – until then, have fun.
Depending on how heavy you are and how rough you ride it, the square tapers on the Nimbus may hold up for a long time. If you want to be agressive, you should be looking at more expensinve MUnis that give you both splines and a 3 in tire.
It is really a terrific value for the money. I’ve had it for over a year and love it. Nothing has bent from my riding. Weight wise, it is also on the lighter side because it has cotterless cranks instead of a splined hub.
Actually, the MUni I bought is the Qu-Ax, because I wanted to add a brake. The Qu-Ax has splines, 3 inch tire, and brake mounts.
btw – If anyone wants to add a brake to the Qu-Ax, beware. The fork has brake mounts, but UDC doesn’t have anything on which to mount the lever on the one inch seat post. I am using a smaller seat post with a shim.
