After purchasing a Schlumpf 27.5" earlier this year my 36er has been seeing quite a bit of down time. Seeing as the Guni suits my needs much more than the larger wheel, I am considering selling the 36 to a good home somewhere on the east coast. The specs are as follows.
Specs:
Coker Steel rim
29" Tube Stretched to fit *see note
Steel spokes
Nimbus Superwide Square Taper Hub
Nimbus Nightrider Tire- with original little rubber fuzz still on it!
Quick release seat clamp
Kris Holm FreeRide saddle
MountainUni Disc setup:
Sinz Dual hole 150/125mm cranks
Mountainuni Disc tab welded to frame
Avid Juicy 3 Caliper
Pics:
Currently the seat does not have a T-bar attachment, so the buyer would need to either buy the KH T Bar setup or the small lever hanger from UDC, or we may be able to negotiate a price on the adjustable T-Bar setup currently on my Schlumpf.
- At the time that I re-set up this unicycle I was working in a bike shop and somehow developed holes in all of my dedicated 36" tubes (probably from pre-bikeshop tube installation days) so I decided to go with a stretched 29" tube due to availability, weight and price advantages. It was a great decision, and I highly recommend it. The significantly lower price and weight of the 29" tube means if you screw up once it is still cheaper than buying a dedicated 36er tube, and they are available at any bike shop. I haven’t had any flats on the 29er tube, and it is slightly easier to get up to speed.
Price: I’m not really willing to negotiate on price, as I don’t need the money right away. With the addition of the Disc brake and the various upgraded components, I think $400 is fair when compared to the price tag of $450 for a new UDC titan.
Location: Tri-State area, specifically Hudson Valley, NY.
I may figure out pictures in something better than link form if there is a large interest.
