Nimbus Mountain Unicycle Black 24" (Perth, WA)
For sale near new Off road Nimbus mountain unicycle. I have had this for a short time and only used it rarely on a few occasions so I have decided to sell it. This is a great Mountain Unicycle for beginners and experts. Very good condition only damage is the “N” sticker has fallen off the front of the unicycle.
$290
Perth, Western Australia.
Muni riding is about attacking the big stuff, the small stuff and everything in between. From the tallest peaks to the most technical descents. The Nimbus 24" Muni is easily the most versatile unicycle you could own on the market at a knock out price
Product Description
Features:
Saddle: Nimbus gel (black) Second generation KH design base with front lift handle
Seat post: Nimbus 25.4mm x 300mm chromed steel or aluminium with a welded rectangular mounting bracket, 4 hole
Seat post clamp: Nimbus (black) double bolt, aluminium
Frame: Nimbus II MUni 24" (black) steel with 42mm machined maincap bearing housings, with magura brake mounts
Hub⁄axle: Nimbus ISIS (black) 36H, hardened CrMo splindle,100 mm center bearing to center bearing
Spokes: 14G. stainless Chrome (231mm in length for 3X) with silver nipples
Rim: Nimbus Dominator 2, 24" (black) 36H, 42mm wide, aluminum doublewall, reinforced eyelets, ERD 492
Rim strip: Rubber
Tube size: 24" x 2.7"- 3.0"
Tire: Duro wildlife leopard 24" x 3.0"
Crank arms: Nimbus Venture2 (black) 150mm, ISIS splined, aluminium
Pedals: Nimbus Venture, reinforced plastic body with steel removable pins, backing plate for added durability and CrMo axle with 9⁄16 threads
Bearings: 22mm x 42mm
Approx. cycle weight: 14.5 lbs
