Nimbus II Frame?
how does this frame compare to a qu-ax trials frame, and would it be a good, bad or neutral switch? :thinking: thanks a lot guys!
Edit: plz tell if link wont work… im trying but it wont and it mit just be my comp… thanks
The link doesn’t work but the Nimbus II and the Qu-ax trials frames are really similar. You wouldn’t gain much by switching. You might lose a few ounces.
pointless to switch, apart from the fact those new nimbus frames have machined bearings so are easier to change wheels with. But not worth it if you have a qu-ax frame.
thanks guys… srry about the link
