I struggled with the decision of what compound to get on my Maxxis HighRoller. I ended up with the 3C compound but might opt for the MaxxPro compound on my next Maxxis tire. We will see how the 3C wears. Any insight on which Maxxis compound is best for MUni is welcome. I will say my LBS said “Wow, that is one sticky compound!”.
What follows is excerpts from a review over blister-gear that has me second guessing my choice of 3C.
I looked at the sideknobs on the tire. On one side, the knobs were showing stretch marks. This happens somewhat quickly on all soft compound tires, but this was only in one section of the tire and only on one side. Plus they’d only seen about 6 runs up to this point. I don’t know if I had this one solitary crash because of it, but I started bending the knobs of the 3C front tire over with my fingers. They definitely fold over easier than the 2.5 3C versions I’d had in the past. Just for fun, I busted out my calipers….
The width of the sideknobs on the new 2.4 High Roller 2 are about 6.4mm and 6.7mm at the center. The width of the knobs on the old 2.5 High Roller are about 5.7mm and 8.0mm. That 5.7mm knob on the old ones is supported by two ribs that measure about 9.5mm and 8.0mm. Look at the blue knob C in the diagram. The ribs are much larger on the old tread. And the pink knob D is much smaller on the new one. I’m not dumb enough to go crazy about this just because I blew a turn, but the trend continued for the next few weeks of riding these things—not crashing, but certainly cutting completely loose far easier than on the old tread design. These sideknobs not only initiate a drift easier, they just give up sooner all together.
I sincerely wish that Maxxis had kept the thickness of the old sideknobs. The change in angles and the ‘fuse’ knob would still achieve the more gradual drifting, but both the drift and the ‘normal’ cornering would have been better supported. Keep in mind that I do hold Maxxis to a higher standard because they are one of the few companies that don’t put out a whole lot of tires that have knob shapes working against one another. Literally every single tire company out there does something glaringly stupid even in the tires they sell the most. Maxxis, however, has done a good job the last few years of at least putting out tires that are consistent in their goals within an individual tread design (the old High Roller with its dumb braking edge is around 10 years old). The Minion DHR tires suck, but at least they don’t have knobs that send your tire in the opposite direction you’re leaning the bike.
I’d say the High Roller 2 corners and drifts better than 99% of what’s out there, and brakes with some of the best. But in a 3C compound, they could have made the sideknobs better. The thinner knob design has proven to accelerate sideknob wear AND compromise the one single thing the old High Roller was so exceptional at: grabbing like a rail and holding your wheels there.
I’ll be putting the 60d/Maxxpro tire on the front of my bike fairly soon, with the expectation that the sideknob support will be better. But I know the braking will suffer, and the general compliance over rocks and other potentially slippery bits won’t be as good as the 3C version. I also know that I won’t be buying another 3C version for the front of my DH bike.
Maxxis has been pretty good about letting their better DH tread designs filter down to the smaller sizes, and I’ve happily run the old 2.35 tires on my trail bikes. I’d be surprised if they released a 60d compound smaller version that I didn’t like on my smaller bike. The tread is really good. The sideknobs in soft compounds could be better.
