I recommend using the Nimbus Bearing Puller instead of one from an auto shop. It is very easy to use, and you don’t need a washer or anything to protect the axle. Just put it in place, use one wrench to hold the bearing puller still and one wrench for the bolt on the bearing puller.
Nice tool, and with the help of a coin it works with the new Q-AXLE as well ;)
