This is a well-loved Nimbus steel 29 uni (sometimes referred to as the Drak).
The frame has its share of battle scars but they are all cosmetic. The wheel, tire, cranks, pedals, and disc rotor are new. The brake is in good shape with no issues. Saddle, handlebar and post are also in decent shape with some cosmetic scuffs.
I’m asking $300 plus shipping.
Shipping is from 85602 Box: 29x29x8 ~ 13lbs
I prefer payment through Paypal.
Specs:
Frame - Nimbus Steel 29 Muni frame - Black (with Nimbus 2 bolt seat clamp)
Wheel - Nimbus dominator 2 laced to a Nimbus disc hub
Tire - Schwalbe Big Apple 29x2.0 with tube.
Cranks - 125mm nimbus ISIS cranks (new).
Seatpost - Nimbus 25.4mm x 200mm aluminum 4 bolt
Saddle - Velo Uni saddle ( like way-old KH / Nimbus) - This saddle has had the base flattened and the foam carved down with a center channel. This adds to long-term riding comfort and makes the shape more similar to a current Nimbus freestyle or stadium (but the foam is noticeably softer).
Pedals - Nimbus Studded Plastic pedals (new).
Brake - Shimano Deore(?) Hydraulic Disc Brake (used -good) - 180mm rotor(new) - Nimbus D-Brake mount (new).
Handlebar - Coker steel handlebar with KH style barends
Options:
Tire - I can swap the tire for a used (~50% tread) Hans Dampf Super Gravity tire for a offroad use. This tire can be setup tubeless or tubed.
Cranks - I can swap the 125mm cranks for a set of almost new qu-ax 145mm cranks (http://www.goudurix.com/us/cranks-zeroq-145mm-isis.html)
Saddle - I can swap the saddle for a Kris Holm Freeride or Street saddle for $50 extra.
