Nimbus 26 Steel Muni - Red:
This is a well-loved Nimbus steel 26 mountain uni.
The frame and cranks have their share of battle scars but they are all cosmetic. The wheel is true with a few minor scuffs on the rim. The hub is in good shape with no issues or creaks. Saddle and post are fine.
I’m asking $200 + Shipping from Southern AZ 85602. I take Paypal.
Specs:
It is spec’d close to the nimbus red 26 mountain unicycle on UDC. http://www.unicycle.com/nimbus-26-inch-mountain-unicycle-red.html
Frame - Nimbus Steel 26 Muni frame - red (with Nimbus 2 bolt seat clamp)
Wheel - Nimbus dominator 2 laced to a Kris Holm Moment hub
Tire - Duro Wildlife Leopard 26 ( about 75% tread left). The tire is setup tubeless, but I can changed it back to a tube if desired.
Cranks - Super stout tubular cromoly 152mm ISIS cranks. Cranks have a low Q-factor like Nimbus cranks.
Seatpost - Nimbus 25.4mm x 200mm aluminum 4 bolt
Saddle - Velo Uni saddle ( like way-old KH / Nimbus) - This saddle has had the base flattened and the foam carved down with a center channel added. This greater comfort on longer rides and makes the shape more similar to a current KH Freeride ( but slightly flatter and the foam is noticeably softer).
Pedals - Cheapo used plastic pedals - they work fine, but you’ll want to replace them.
Options:
Tire - I can swap the Duro for a used Hans Dampf Super Gravity tire for a lighter more nimble feel. This tire can also be setup tubeless or tubed.
Cranks - I can swap the 152mm cranks for a set of used qu-ax 145mm cranks (
http://www.goudurix.com/us/cranks-zeroq-145mm-isis.html)
Saddle - I can include a Kris Holm Freeride saddle for $50 extra.
Brake - I can include/install a Magura HS-11 Hydro rim brake kit with an under-the-seat lever mount for $50 extra. These brakes are light, out-of-the-way, and stop well (esp. in dry conditions).
