Nightrider tire pressure
I recently spoke to UDC about a brand new nightrider tire blowing off the rim and he asked me what pressure I run and where I’m from. I told him I’m from Austin, Tx and I run usually 55 to 60psi and he immediately said that that is way too high a pressure for that tire. He also said because of the heat in Texas I should probably run the pressure around 40psi. This is my third or fourth nightrider tire and have always run 55 to 60psi without a blowout. Just wondering if anyone else has had a problem like this. Thanks.
Aj
From the UDC Nightrider page:
“Pressure Rating: 35 - 65PSI (250 450kpa)”
Personally, I like a firm tire, and usually run about 50-55lbs. Never had a problem, but if the temp’s around 100, it’s too hot to go out riding, imho.
How old is the tire? Could be a defect.
It’s a brand new tire. Got it from UDC last week.
Lance,
I ride in 100+ as much as possible. I thrive in the heat. I guess I live in the right place. Haha.
Aj
When I was in houston tx I ran it at 50 to 55 psi
They’re rated to 65 so the guy you talked to doesn’t know what he’s talking about…
I run 45, but that’s only cause it’s tubeless. I ran 60 tubed.
I have posted this earlier in another tread:
My first Nightrider exploded. Sidewall blew out. This was a brand new tyre, and I had pumped it to 65 psi which was ridiculous since I was riding on gravel roads. I had ridden for an hour maybe when I left it in the sun and went to buy something to drink. And then after 1 or 2 minutes: BANG!
UDC Sweden replaced it free of charge.
After that I’ve never ran more than 50 psi.
A couple of the riders in Dallas did. One guy looked into it in depth, looking at specific wheel and tire batch combinations. I’ll steer them to this discussion.
I run mine at 65 psi routinely without incident (including at the Hotter n Hell Hundred when it was 109 degrees).
I believe that the bigger a rim gets, the less secure is the “security” of an imperfectly seated tire vs, tire pressure. In other words, the combination of a large rim and high tire pressure can increase the chance of a blowout if the tire is seated just a bit off, where it probably wouldn’t make any difference at a smaller rim size.
65 psi sounds really high to me, as I find that higher pressures make the tire too “square”. It doesn’t turn as well for me, and I find that a much lower pressure makes it track more nicely around curves, as well as providing a smoother ride. At what cost in friction I’m not sure, but that’s what works for me. All you high pressure riders are making me curious though–maybe I’ll try a much higher pressure again some time…
I go by what “feels” right, not by a number on a tire gauge.
I am in with John.
I run mine at about 20 - 30 PSI. At the higher end it just feels harsh and bumpy.
For the lower end as long as you are not hitting the rim as you ride over things (Bumps in the trail, curbs etc…) you should be fine.
Otherwise go with your feelings. If it is to soft it will feel squishy and wobble to much and just feel spongy. If it is to hard then it will feel like you are riding on a hard board that just smacks you in the neither regions every time you go over a bump.
At UNACC i don’t think i ran anything over 25 - 30 PSI even for the marathon.
Davey
When i put a foss tube up to around 50psi and it really didnt like it,
when off like a shot gun just below my head and blew out the bead from within…
I think my ears have stopped ringing now so my new Nightrider is around 40psi. More for me seems a bumpy rough ride. Less tends to not roll as well but quite grippy and forgiving.
Depends what surface you mostly ride and to what comfort and performance level you want from it.
I will be going tubeless for my 36 Schlumpf build if i get her to bead. Not getting flats and being able to safely run lower pressures is really appealing.
I am a stickler for forever running way to much pressure and miss out on so much more performance of what i ride
I used to run high pressure also but have dropped down some for traction
Scotthue runs 30 psi and he is a world champion. I run up to 30 psi myself. I find 65 psi makes the wheel a bit twitchy and bouncy and therefore less stable. It gives you more speed with less control. If you leave your wheel with 65 psi, parked under direct strong sunlight the wheel rim can get very hot and may cause the fully expanded tube to expand even more until it explodes. BOOM!! A blow out may be caused by a flaw/weak spot in the tube.
Hmm… I run 65… Because I always have. I attribute it to coming from a road cycling background, where 120 psi was pretty normal. I’ll be going out today to try 30.
I feel… Incurious.
Let us know how you get on with 30psi…
It may be that there is no correct answer
Breathing some new life in this thread… It recently came up on a FB group and it got me testing.
I’ve always run my 36er, which is ridden almost all on pavement/road/side walks, at 20-30psi.
Initially I ran it at that low pressure to make it easier to free mount. I still believe FMs at a lower pressure is easier than at a higher pressure.
The downside of the lower pressure is it limits how fast I can pedal. When I attempt to go faster the wheel starts “bouncing” into the pavement. Obviously it doesn’t come off the ground… its more like the tire is being compressed into the pavement on each stroke.
Still a skeptic, and a little concerned about blowing the tire off the rim, I increased the pressure to 40psi. I have to admit it did make a big difference reducing that tire compression when pedaling faster.
I was using 135mm cranks… for me that is on the short side, considering I am most comfortable with 150s, but once I went to 135 I really appreciated the shorter foot circle needed.
I don’t have enough experience at 40psi to say, but I’m hoping it helps with hill climbs. I seem to be able to climb the smaller hills I’ve ridden at 40psi with greater ease and more speed. Fingers are crossed that it carrys over to my favorite “big hill”, the one that I don’t always make it up. I’ll be testing that out tomorrow.
As it stands, there are top notch riders that run 30psi… and other pros that run 60. For us mortals, we have to experiment and learn first hand what the pros and cons are.
