Re: Re: Next step
I was wondering why it was taking you “so long” to learn. Because you seemed to be having so much fun with the magic of learning you actually inspired me to “start over” with learning how to ride unicycle.
Tonight, I was able to make 20 pedal pushes!!! (Pedal pushes are not revolutions or even half revs - they are the number of times I apply pressure to each foot). It is the easiest thing to count.
At first I was procrastinating; then, I got half dressed and rode around in the house denting the diswasher and scratching a cabinet. With that, I put on full armor and made it around the block (in 1-15 push attempts) for a grand total of 1.33 miles. (I did .60 miles in the house) I was proud of myself because I am well on my way to learning to ride over again.
By the end of the week, I will be able to ride 5 miles!
What helps me learn faster is to:
- Isolate a particular skill (freemounting, riding, turning)
- Set an arbitrary difficult distance goal.
- Continue until the distance is reached.
- Set frequent practice times (today’s session was after 11pm).
What helps the most is that I have an odometer on my unicycle to help me measure my progress. I am very goal-oriented and have a tough time “just having fun.”
Jayne, I can’t wait for the day that you post that you have learned to ride (I bet it will be soon - at the 10 hour mark).
Digigal1, Jayne, I highly recommend both of you “take it to the field” find football game sized field and attempt to ride. Your wheel may sink, you may hit bumps that throw you off, you may end up dirty. However, you will gain confidence because falls won’t hurt so much, you won’t have to worry about going in a direction, there will be no obsticles, and you will develop your pedalling technique faster.
Believe it or not, I find it easier to ride on grass, uphill and downhill than smooth pavement - because my common beginner’s flaw (overpedalling) was offset by the need to use force (to overcome bumps, hills, or slow down). I started to learn to ride (again) last week, and the first thing I did was “take it to the field.”
Today’s session was on pavement and I look forward to actually making 5 miles worth of attempts tomorrow.
Savor learning the basics - it is the most satisfying aspect of unicycling.
