> The story goes that unicycling was “invented” by penny farthing riders
> who discovered that they could lift the small wheel. Is that something
> you have tried and is it easy to do?
The level of difficulty is in direct proportion to the size and weight of
the bike. I used to do this trick on a small penny farthing bicycle that
was part of the Bill Jenack collection. This was a Japanese-made bike
from the 60’s, with a 28" front and 16" rear wheel, basically a penny
farthing for kids. You can see a picture of a young John Jenack riding it
if you own a copy of Jack Wiley’s Bicycle Builders’ Bible (available from
the USA inc.).
In the 1980s we painted this bike all black, to make it look antique.
It worked very well! I used it in some shows and period events. Because
of its small size and light weight, it was easy to get it up on the
front wheel, and keep a little pressure on the seat to keep the back
wheel in line.
But I have also tried it on a 46" Rideable Replicas bike, and it’s a lot
harder. I did this in a show the other day, in downtown Davis, CA. Davis
uses a penny farthing as the city logo, so I felt some responsibility to
get it right. But with only one minute of pre-show practice, my
demonstration was less than perfect. The bike weighs probably 60# or more,
and you’re way up there on that seat. Don’t want to have to dismount
forward, because those handlebars are in the way! The dreaded header.
To ride the penny farthing on the front wheel you have to build a small
amount of speed, then apply braking force to lift the rear wheel. Once
it’s up, you have to do two things. First, balance yourself on that
front wheel, which is plenty heavy (and the crank arms may be short).
Second, you have to keep the frame and rear wheel relatively centered,
or they’ll fall to the side and scrape the ground (followed by you
scraping the ground).
For best results, I try to keep the seat against my butt, by applying some
pressure to the handlebars. So all you have to do to master this
“historic” unicycling trick is to be able to do that, while riding that
front wheel with your hands on the bars.
Yes, expect it to take some practice. Before tackling it seriously,
practice dismounting to the side. Protect the bike as it may bend on
impact. If you don’t have experience with big wheel unicycles, try to get
some, as it will help a lot when you’re up there.
Good luck, John Foss, the Uni-Cyclone jfoss@unicycling.com
www.unicycling.com
Frisbatarianism (n.), The belief that, when you die, your soul goes up on
the roof and gets stuck there.
