That’s the general consensus, and I personally think it’s a great unicycle. You have to pick the wheel size you want epending on your height and what type of unicycling you plan to do, but for beginners I think it is an excellent choice.
just try to make sure when, or if, you cut it with a hacksaw, you try to keep the cut clean. flat, and smooth, then kinda smooth it up when your done, so you dont scratch up and ruin the inside of your seatpost =p
My cut was anything but flat, but its still ok, as long as the bottom of the seatpost dosen’t hit the bottom or stick out of the frame its good.
I guess I could borrow a grinder and flatten it right off.
For heaven’s sake use a pipe cutter. Your hardware store, your LBS and your plumber all have one. In my experience, unless you are a total sasquatch, you’ll need to cut doen the seatpost. You may also want to have a file handy to smooth things out, no matter which tool you use to cut the tube.
My vote, BTW is for the LX because that is what I learned on.
i learned on a 20" cyclepro. i didn’t think to cut the seatpost so it was almost touching the tire when i started. then, of course, i raised it a couple of inches because i got better at it. i’ve still got my cyclepro but i’ll probably need a new one soon for trials.
Go Lx! That’s what I’m learning on and it is taking the beating I’m giving it very well. I love it (go for 20" too, I have a 24" but now I wish I would have gotten a 20)
-Carolyn
im only bout 5’10" and can have the post above the frame by an inch or two, but cut it about an inch while trying crankflips(someday ) so aS TO NOT NUT MYSELF too bad, and its like PERFECT!! at that height. i do have really long legs though.
