Hows it going? My name is Aaron Oss and I’ve recently designed and manufactured 24" and 26" Muni frames. I’m trying to determine if there is a market for them.
The frames are made from solid aluminum with main cap style bearing housings. The frame is equiped with V-brakes and are designed to fit a 3.0" Gazzaloddi tire. I used a Suzue hub and mammoth rim for wheel set - could redesign frame to except a profile splined hub if there is a demand. Also used miyata saddle with 22.2mm seat post.
Thank-you for you time and I look forward to recieving you opinons and thoughts.
I don’t know that this is the best place for a thread like this. You’d get more replies in r.s.u anyway. You may want to change the ‘neck’ to accommodate a bigger seatpost. It’s easy to shim a 22.4mm post to fit a bigger frame. Have you got any photos of your frames?
your unicycles look really nice but your in canada by the look of your t-shirt.i am in uk so the postage would be to much i would guess your unis are out of my price range any way how much are you looking at for them
I’d be happy if that’s what I created for myself, but I certainly wouldn’t buy it over a nicer looking (and mostly likely way cheaper) Bedford unicycle
