I would like to call on the collective wisdom of the Uni-community on this one:
I was so excited to finally get my new kh 36er today, and so after carefully putting it together, I took it out for a test ride, and almost immediately after mounting and within the first couple of revolutions, I felt a distinctive “knocking” sensation that appeared to be coming from the wheel. I checked to see if maybe the brake pads were rubbing, or maybe the assembly was loose, but that wasn’t the case.
I had initially checked the bearing caps during setup, and they were sufficiently snug; just enough so that the wheel would rotate freely without stopping to quickly. Then I double checked the cranks, and they were as tight as could be, with no apparent gap(s) in the spacers.
At this point I got back on and rode for a short distance, but the knocking persisted. I dismounted again and this time I grabbed the wheel and tried to see if there was any side to side play…and sure enough, there was! Not a great deal, but certainly enough to feel it while riding. The problem is, I assume, that if it is a loose hub, that it will likely continue to get looser, and even as it is now, the slightest torque applied to the cranks, causes the wheel to knock. It’s actually more of a jarring feeling than an actual noise, although I can hear it somewhat as well.
Now that I think about it, the rim is probably slapping against the brake pads with each revolution because of the torque on the cranks, but it doesn’t happen when you simply hold the uni and spin the wheel, since there’s no torque generated in that instance. And because the hub is apparently loose, it just makes the already inherent “flex” of the large wheel all the more pronounced.
Could it be that this new splined hub is faulty in some way, or maybe not fully pressed on to the splines? I don’t know what else I can do to eliminate the problem, but I think I’m right in assuming that there should be no “play” in the hub that would cause the wheel to move side to side. Any thoughts? Hopefully Kris will see this thread and maybe have the answer.
