ok so sorry for the past few months of confusion but i have figured out all my sources and now i can build my runi and giraffe im using a 26 inch wheel with front disc hub and ive bolted the sprocket to it
so will be strong as it is all one piece hub
im using three piece mtb cranks and my uni seat off my nimbus ill just swap it when i want to ride it,this uni might be 8ft as ive got a fair bit of steel ill be using some heavyass steel so frame wont bend or ill off centre it anyway… am starting welding on wedsnday.
Now I want to see that when it’s done!
Why are you telling us this? get out and make it.
I finished making another giraffe the other week, needs painting and then maybe I will post some photos.
sorry just askin for oppinions onwhat u guys think and i have nothing better to do then waste away on unicyclist.com unless i had a welder which ill be getting in a few months hopefully but sorry for building hopes
ok its now done i promised you all id get it done by wedsnday i did it for 1 hour last wedsday then 1 hour monday and 1 hour today and now its done
Cool. How’s it ride?
im still too chicken to ride it at the moment but ive idled it and its fine ive got to shorten the forks abit theres abit of flex there…im going to try and get the nerve up to ride it today
Lol. Good luck.
Blimey that’s tall
Looks to be about 8ft going by the wheel size.
Rob
Slick!
Watch your head.
That looks mental! Good luck
If you are not using the outer cranck ring try putting some rubber, ducttape or something over it.
Or replace it with a plain metal ring like a bashguard. You dont want to land or get caught on that while 8 ft in the air
ok so i just rode it around the back yard and wow i sure did create a beast it rides so nicely
