Some specs- echo 48mm
weight- 710g
30mm drilled holes
“Extra thick side walls, dent proof”
wayyy rad-er than a dx32…
weight- 710g
30mm drilled holes
Am i missing something or is there supposed to be something behind those holes? Wouldnt the tube be shoved up against them?
How much are they?
Yes. They use a very sturdy and wide rim strip. Bonus points if the rim strip is a nice bright color.
you have rim strips…
Im not sure yet… Im guessing around $60
THE WEIGHT LISTED IS FOR A 26"
Meh, that’s not much different from the Try-All rim, and at least the try-all comes in 19". In the end drilled rims are weaker, but if you don’t need the extra strength, they can be good. The try-all also has what appears to be a better, stronger profile.
In case it aint obvious, I lam biased a bit in favor of the rim i use.
BTW, John is right, they have super wide rim strips. Still, there is some bulge factor, but it just makes the tire a bit mroe squishy, which is nice.
And they come in green! bonus points. Now a decent green frame…
the thick rim strip you have to use must add to some of the weight you just lost by drillin those holes
Seems very shallow i.e. not much distance between the two layers, but that might be because the rim is much wider than normal, 48mm seems a nice compromise between the DX-32 and the large marge (64mm), sounds like a great Muni rim that would give better tyre support than the DX-32 and still be light. Does the Try-All come in 24" and 26"?
Edit:Argh, no 24" version available.
so are those wider than the try-all?
i looked it up myself.
Try all 47 wide
Echo 48 wide
you can just lace your wheel differently
