Need sprocket for my EBay Giraffe
Trying to find a replacement upper sprocket with 5" crank arm for a
Matthews giraffe.
Wondering if this Miyata SkyCycle sprocket would work:
http://www.unicycle.com/shopping/shopexd.asp?id=169
Anyone have a SkyCycle? Does it take a standard 1/8 inch single-speed
chain with 1/2 inch links?
Where do you buy stuff like this in general? I was looking at BMX bike
parts suppliers on the web but I could not find this particular part,
probably because I don’t know what it is called.
This sprocket will go on my EBay giraffe mentioned in an earlier
(8/16/02) post by billnye (“Congrats on the purchase, Mark”). That
giraffe was not quite as wonderful as it appeared. It seems to be a
modification of a taller Matthews – it looks just like my 6-foot
Matthews except it has been cut off just above the frame, shortened by
18 inches or so, and re-welded. Looks like an amateur welding job, but
at least they got it on there straight. The upper sprocket/crank looks
home-made with the sprocket welded onto the crank arm. Both cranks feel
slightly bent. Needs a lot of work but it will be fun to play with when
I finally fix everything.
Thanks,
–Mark
Mark Newbold
Montpelier, Vermont USA
Alternate email: manx@sover.net
