I need to remove a cheap crank from a square-tapered hub. The thread on the crank is stripped beyond salvation. I have no idea how
to proceed. Can I save my hub?
I’m considering just taking the nut off and riding around until the crank works itself loose. Somebody stop me.
Crank removal tips please.
Thank you.
well just use a cranks puller and how the hell did you strip it
You can try using a bearing puller to remove the crank. But that would require that you buy a bearing puller if you don’t already have one.
The cheap and easy way would be to take the nut off and ride around till it comes loose. Just be careful it it’s a steel crank. Steel cranks can damage the hub taper much more easily than an aluminum crank.
