I set up a Gallery to show all the sports I pursue (and some I no longer do) but can’t figure out how to put all the photos in a single album that can be launched as a slideshow. It appears as though each photo is in a separate album. Plus, there is a long list of error codes at the top of the page.
Can someone give me a little guidance on fixing this?
The error codes have disappeared. Thanks to whoever fixed that. I still can’t figure out how to incorporate all the photos into a single slideshow. Others have done it. Any suggestions?
my dad once went barefooting he said it was surprising le easy but a Ton of fun I ask why only once Because I fell And it felt like hiting cement at 25 mph, is that true? And How do you learn hand balancing the trick in your avaiter?
Barefoot water skiing can be hard on the body. To ride smoothly on the water it helps to be doing at least 40 mph. If the front of your foot dips you come to a sudden halt with the result that your body does an extreme backbend. Nothing that a dose of Advil won’t cure.
The handstand takes time to learn. I can still balance a chair on two legs (very briefly). I had competed in gymnastics as far back as 1964 and continued to do standing back flips until ten years ago. Get a good coach. I was self taught and had to unlearn some bad habits. Your uni riding skills have given you a good start in the balance department.
The error codes were an issue with the cache system, just clearing the cache cleared the errors. A bug on the server end, nothing about what you’ve done.
For the slideshow, there should be a link on the left side of the page so you can view the album as a slideshow.
