Re: My helmet saved me, and broke
On Mon, 29 Aug, onewheeldave <> wrote:
> Ian Smith wrote:
> > I’m not trying to convinvce you otherwise. There’s no need to
> > convince anyone otherwise, the ‘otherwise’ is simply fact. Over the
> > period that the helmet wearing rate has risen dramatically, the
> > serious injury rate has risen slightly.
> > If your assertion that helmets do more good than harm is true, how
> > can this be?
> Ian Smith, you seem to be saying that many of those supporting helmet
> wear are making invalid assumptions ie seing it as ‘obvious’ that they
> offer protection, when, in your eyes, there is no real evidence.
Not quite - the objection is that the evidence shows the opposite -
increasing helmet wearing (both voluntarily and by mandating it)
increases the rate of serious injury to cyclists.
> So, when someone says it’s ‘obvious’ that, in a head impacting the
> ground scenario, a helmet will tend to protect the head; it s analogous
> to someone in the 12th century believing the earth to be flat because it
> is ‘obvious’.
> Is that a correct summary of your opinion?
It’s analogous, yes.
> You yourself seem to believe that helmet use is actually, at best,
> inneffective, and, at worst, may actually increase injuries.
No, I’m saying that at population level, increased helmet wearing rate
DOES correlate with an increase the rate of serious injuries.
> You’ve concluded this because of studies which have shown that, in
> places where helmets have been made compulsory, injuries have actually
> risen.
And also where helmet wearing has risen without compulsion, the
serious injury rate for cyclists has not tracked that for pedestrians,
whereas before anyone wore helmets, the rates tracked each other quite
consistently.
That is, over time, the pedestrian injury rate fluctuates, but is on a
long-term downwards trend (at least in the UK). When no-one wore
helmets, the cyclist rate closely tracked the pedestrian rate (but at
a different rate). Since cycle helmets have become more common, the
cyclist and pedestrian rates have diverged, with the cyclist rate
showing less improvement than pedestrian rate, suggesting something is
making cyclists relatively less safe - and this ‘something’ started
happening at just about the time that cyclists started wearing
helmets.
> and, if possible, also clarify, the breakdown of injury increases in
> those studies ie taking three categories of 1 deaths, 2 serious
> injuries, 3 non-serious injuries- how have each of those categories been
> affected. I realise you may not have such info, but i think it is
> relevant as, for example, a rise in injuries could actually be caused by
> helmets doing their job because people who may, previous to helmet
> wearing, have died, will now be pushed into the ‘injuries’ categories,
> leading to an increase in the injury stats.
No, that does not explain it - the rate figures in question are ‘ksi’
which is ‘killed or seriously injured’. Converting a death to a
serious injury does not push the person into the category (or out of
it).
I don’t have a breakdown of minor injuries - it’s the ksi rate that is
generally recorded long term.
As it happens, I expect helmets will have a beneficial effect on
minor injuries. I believe helmets are very good at protecting against
minor but painful and inconvenient (and maybe even scarring) injuries
(eg skin loss, blood-loss). However, none of the mandatory helmet law
proponents campaign for helmets in order to protect against painful
non-life-threatening injury, at the risk of increased death or serious
injury. I also observe that I have no substantiated basis for this
belief, so if someone came up with some figures that claimed to show
otherwise, I would examine them very carefully - I wouldn’t discard
them out of hand because it’s “obvious” that they must be wrong.
regards, Ian SMith
|\ /| no .sig
|o o|
