My first MUni trail ride
I have watched George Peck’s video titled “Rough Terrain Unicycling” and I was
inspired to build myself a 26" wheeled Mountain Uni (MUni) this winter. I bought
most of the parts from Tom Miller at the Unicyce Factory: a Semcycle 28" frame,
a Semcycle Deluxe hub, a 16" seatpost and an “old style” Schwinn saddle.
>From a bicycle mail order house I bought spokes and nipples, a Mavic 231 PSP
alloy rim and a 1.9" Performance ATX inverted tread tire.
I have been riding around on the street with a few brief excursions onto grass
and dirt, getting familiar with the feel of the larger wheel. I live near
Topeka, Kansas, and I finally made it up there to ride my MUni on the trails at
the Governor’s Mansion. It sits on 1000 acres of undeveloped woods along the
south side of the Kansas River in the north western part of the city. This land
has been made into a public park.
Originally I cut down a set of 170mm aluminum alloy bicycle crankarms (that’s
about 6 1/2 inches) for really rough terrain and they work great. For this ride
though I left on my “street” cranks: 5 1/2" long Matthews steel unicycle
crankarms. I originally bought GT brand alloy BMX pedals with studs for better
grip but I soon retired them in favor of Wellgo plastic bear-paw style pedals
that I found at the local Wal Mart. The GTs were nice looking but they felt
heavy and they gripped TOO well. When I saw what the studs did to the soles of
my shoes I knew I didn’t want them biting into my shins.
The wooded area has a biking/footpath about 6 feet wide, covered in crushed
limestone. The path winds up and down over these steep hills in a circuit of
about two miles. From this path singletracks wander off into the trees. Some of
them are marked with posts every hundred yards or so but many are
“undocumented”, created by the many mountain bikers that come there to ride.
I took my first circuit around the gravel path, ascending and descending grades
as steep as 25% (a 2.5 foot rise in 10 feet). I had a little trouble on some of
the steepest portions where sand had washed out onto the path and made it hard
to keep traction. At these points I was standing on the pedals and holding onto
the nose of the saddle for added torque. I would spin out in the loose sand.
Perhaps a more aggressive tread pattern would have held traction; this is one
area where I am still fine-tuning the MUni. I have read that a too-aggressive
tread makes turning and twisting very tough. After a few attempts, I also found
that I was leaning too far forward trying to get the pedals “over the top”. I
found that if I didn’t lean so far forward, I got better traction without losing
too much torque on the pedals.
As I was climbing up one hill, I met a jogger going the other way. He was so
startled and impressed that he didn’t remember to ask where my other wheel was.
He said “Well, that’s original.” and asked if I could actually get up the hill
on that thing. I said “Sure, if it’s not too sandy”.
Encouraged with my success, I started exploring the singletracks. That day
they were simply dry paths in the loamy soil, with the usual tree roots and
rocks on the steeper parts, and ruts where the path had crossed or merged with
rainwater runoffs.
For the most part, I relied on momentum and the larger diameter wheel to roll
over stuff. I found out right away that singletracking on an MUni requires
constant tight focus. I would roll over tangled roots, ruts and rocks, only to
be thrown by a tiny depression in the hard packed dirt. The dappled sunlight
falling through the leaves overhead made reading the trail tricky. I suppose the
Mountain Bikers among us are used to that but for me it was a big surprise.
Descending was trickier than I though it would be, you have to lean forward a
bit to roll over the roots. It was tricky because I was leaning backward,
applying backpressure to the pedals to control my speed. After stopping cold
against a root and falling off backward a few times, I tried leaning forward
only to find the steep grade was fooling my eye. I had to lean even farther
forward than I had guessed, which with the trail falling away from me made it
feel like leaning out over a cliff. A couple of times I made it over one root
only to bump up against another and go sailing off the saddle forward, landing
one or two feet vertically down the trail. Since no one was watching, I didn’t
feel too bad about grabbing at branches and bushes at times to save myself from
falling over sideways.
I thought I would be doing more hopping but at present this is too much to do
while fighting to maintain direction over obstacles on a steep slope. I hope to
learn this as I gain experience offroad. Remounting on a steep slope is tricky
too. You have to mount into a pedals-level position and try to go forward
immediately or start hopping, bumps make the half-idle rollback mounting
technique very unreliable.
All in all it was immense fun. I guzzled down as much water as I could hold
before leaving the trailhead but after an hour of thrashing around in the woods
I was very dry (and tired!) and had to turn back. I will have to get one of
those fanny pack/water bottle carriers so I can stay out longer next time. Yes,
next time! As Arnold says: “I’ll be back.” Rough terrain unicycling is fun and
challenging. I recommend it wholeheartedly to other unicyclists.
Dennis Kathrens
Re: My first MUni trail ride
|> grass and dirt, getting familiar with the feel of the larger wheel. I
|> live near
Hi. I found your account interesting and would like your permission to translate
parts of it for the Next issue of the the Japanese edition of Unicuycling
International. Is that ok with you?
Oh, it seems that the FAQ has nothing on mountain unicycling. Does anybody know
of an approprate introduction, perhaps past posting tothe list or news, that
couls serve as a basis for an article in UI?
Stay on top, Jack Halpern
>It just proves there is no limit to unicycle riding. Some day someone will be
>riding on the moon. Until then perhaps people will be looking for the lowest
>place to ride, in deep caverns perhaps (as well as the highest place to ride).
>On One Wheel,
>Ken Fuchs <kfuchs@winternet.com>
I knew someone years ago who went exploring with a friend down a deep abandoned
and forgotten mine in Cornwall. They weren’t well equipped, just a small torch
(that’s a flashlight to those with a certain dialect), or experienced - they
just went on a dare. The galleries went on for miles, mostly in good condition,
but with the occasional caved in floor or whatever. They suddenly saw an eery
light in the pitch black and endless silence, hundreds of metres below the
ground. It expanded incredibly fast and before they knew it, it was upon them.
And then it was gone. In their utter terror they just managed to catch sight of
it - a maniac mountain-biker riding at full pelt with a head-mounted torch. He
didn’t even stop to say hello.
And they say unics are crazy.
So when are we going to see the first competition event between the
Troglocyclists and the Speleolunis?
Tim Sheppard tim@lilliput-p.win-uk.net Lilliput Press - Publisher of fine books
in miniature
Path: winternet.com!io.org!vanbc.wimsey.com!unixg.ubc.ca!news.bc.net!news.uoreg-
on.edu!europa.chnt.gtegsc.com!howland.reston.ans.net!news2.near.net!news.delphi-
.com!usenet From: David Winston <winstond@delphi.com> Newsgroups:
rec.sport.unicycling Subject: Re: Broke the fool thing! Date: Fri, 21 Jul 95
01:31:57 -0500 Organization: Delphi (info@delphi.com email, 800-695-4005 voice)
Lines: 23 Message-ID: <pjBBgH1.winstond@delphi.com> References:
<3ucb6f$5ak@sundog.tiac.net> <3uce40$qr1@ns.mcs.kent.edu> NNTP-Posting-Host:
bos1d.delphi.com X-To: Beirne Konarski <bkonarsk@condor.mcs.kent.edu>
Beirne Konarski <bkonarsk@condor.mcs.kent.edu> writes:
>You should have a nut that holds the crank down, and you’ll have to torque it a
>lot; at least 75 foot/lbs. If you are lucky the nut will be flopping around
>behind the dust cover, otherwise you can get a new one from a bike shop, where
>you might also want to get the crank reattached.
One thing to add to this which is critical–DO NOT use the torque of the nut to
reattach the crank arm to the axle!!! Doing this will strip the threads. The
crank arm must be firmly in place on the axle before you tighten the nut, since
it only serves to hold things in place. I learned from Tom Miller to use a
solid, nonmetal object (Rubber mallet, Ball Peen hammer, block of wood + hammer)
to firmly mount the crank arm onto the tapered end of the axle as far as it
would go. The arm should feel almost as “snug” as new. At this point it is safe
to thread on the holding nut and torque to the appropriate foot/lbs.
Happy riding!
David Winston, winstond@delphi.com Huntington Beach, CA U.S.A.
The Catch magazine has had 2 or 3 good introductory articles in the past year.
I’m not sure whether they or the author have the copyright, but I would imagine
they would give permission to use some of the material. Dennis should have seen
these as he has a subscription too.
in miniature
Hi Dennis, thank for your mail, it was very interesting. Due to problem
of video standart, I still haven’t see the Peck’s video (but I hope
their will be PAL version of the video at the next European UNICON, for
European riders).
    But I meet at Eurocycle the guy who have founded a club devoted only to
    mountain Uni. Very impressive ! Unfortunnately, He is not on the Net.
    He use a 20" Uni, because 26" are too expensive and too difficult to
    find, with short crank arm, a notchi tire of very good quality (from
    Michelin), and a "free style bike" saddle, very far from Uni style
    saddle: it's nearly a flat triangle, one angle in front and a flat part
    on the back.
    Thierry (the guy's forname) has developped a special technique for
    mountain Uni, reminding that is aim is to down ride strong slopes, as
    strong as 45 degres (100 %), and with denivelement as long as 800 to
    1200 m. He has already done that !
    He shows me some demo's, two things are very differents from 'standart'
    riders: he's nearly never sat on the saddle, and he always grab the
    front of the saddle with one hand. He hopes a lot, turning the wheel a
    half in the air, and changing of side too. For exemple, in a slope he's
    left side in front of the ground, left crank up (instead it will touch
    the ground), then he jumps, and is down with right side in front of the
    ground and right crank up. It's the same technique that for strong
    slope skiing.
    I was impressed by the high precision of his jumps, he rides down a
    big rock block with flat part as little as 7cmx7cm, hoping from one
    to an other.
    You had to meet him, probably at Unicon, and he will explain you hours
    long all the secret, and meaning of his technique.
    His palmares is impressive: he has ridden the high track of the "Tour du
    Mont Blanc" in France, and down from altitude 5300 m in the Aconcagua in
    South America. He planned to ride from the summit, but to much snow stop
    him. Nevertheless, he is probably the highest Uni rider for now.
    Long ride on your Muni, see you at Unicon.
| Philippe QUAGLIA | CNRS Service Aeronomie |
| Email:philippe.quaglia@aero.jussieu.fr | FRANCE |
Return-Path: NETNEWS@AUVM.AMERICAN.EDU Received: from AUVM.AMERICAN.EDU
(smtp@auvm.american.edu [147.9.1.2]) by icicle (8.6.12/8.6.12) with SMTP id
DAA25301 for <UNICYCLING@WINTERNET.COM>; Wed, 19 Jul 1995 03:45:58 -0500
Posted-Date: Wed, 19 Jul 1995 03:45:58 -0500 Received-Date: Wed, 19 Jul 1995
03:45:58 -0500 Received: from AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM
SMTP V2R2) with BSMTP id 5830; Wed, 19 Jul 95 04:44:33 EDT Received: from
AUVM.AMERICAN.EDU (NJE origin NETNEWS@AUVM) by AUVM.AMERICAN.EDU (LMail
V1.2a/1.8a) with BSMTP id 5480; Wed, 19 Jul 1995 04:44:33 -0400 To:
UNICYCLING@WINTERNET.COM Sender: <NETNEWS@AMERICAN.EDU> Path:
auvm!paladin.american.edu!news.ecn.uoknor.edu!news.ysu.edu!
malgudi.oar.net!news.erinet.com!uunet!in1.uu.net!worm.inch.com!metric!biver
From: biver@metric.inch.com (Biver - TEP) Newsgroups: rec.sport.unicycling
Subject: NYC unicyclists/jugglers wanted Date: 19 Jul 1995 04:11:32 GMT
Organization: The Internet Channel Lines: 4 Message-ID:
<3ui0lk$c56@worm.inch.com> NNTP-Posting-Host: metric.inch.com X-Newsreader: TIN
[version 1.2 PL2]
I know you exist, i see you from time to time in the streets. Lets to the unijug
thing. You know, for fun.
Brad
EAA25945 for <UNICYCLING@WINTERNET.COM>; Wed, 19 Jul 1995 04:11:03 -0500
Posted-Date: Wed, 19 Jul 1995 04:11:03 -0500 Received-Date: Wed, 19 Jul 1995
04:11:03 -0500 Received: from AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM
SMTP V2R2) with BSMTP id 5906; Wed, 19 Jul 95 05:09:37 EDT Received: from
V1.2a/1.8a) with BSMTP id 5637; Wed, 19 Jul 1995 05:09:37 -0400 To:
auvm!paladin.american.edu!zombie.ncsc.mil!simtel!news.sprintlink.net!news.cloud
9.net!worm.inch.com!metric!biver From: biver@metric.inch.com (Biver - TEP)
Newsgroups: rec.sport.unicycling Subject: backward seat??? Date: 19 Jul 1995
04:04:50 GMT Organization: The Internet Channel Lines: 6 Message-ID:
<3ui092$c56@worm.inch.com> NNTP-Posting-Host: metric.inch.com X-Newsreader:
TIN [version 1.2 PL2]
try turning it around. you may be unscrewing the crank by accient. try it and
let me us know. I hav a similar proble with my Myata!
Later
biver
EAA26688 for <UNICYCLING@WINTERNET.COM>; Wed, 19 Jul 1995 04:32:26 -0500
Posted-Date: Wed, 19 Jul 1995 04:32:26 -0500 Received-Date: Wed, 19 Jul 1995
04:32:26 -0500 Received: from AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM
SMTP V2R2) with BSMTP id 6050; Wed, 19 Jul 95 05:30:54 EDT Received: from
V1.2a/1.8a) with BSMTP id 5926; Wed, 19 Jul 1995 05:30:54 -0400 To:
auvm!paladin.american.edu!howland.reston.ans.net!news.sprintlink.net!
simtel!news.kei.com!eff!news.duke.edu!solaris.cc.vt.edu!swiss.ans.net!prodigy.
com!usenet From: BNEK92A@prodigy.com (Daniel Whalen) Newsgroups:
rec.sport.unicycling Subject: circus bicycling :slight_smile: Date: 19 Jul 1995 06:17:18 GMT
Organization: Prodigy Services Company 1-800-PRODIGY Lines: 18 Distribution:
world Message-ID: <3ui81e$13tq@usenetp1.news.prodigy.com> NNTP-Posting-Host:
inugap1.news.prodigy.com X-Newsreader: Version 1.2
Hi everybody, I’ve been enjoying this newsgroup quite a bit. Thank you to
everybody who works so hard to maintain and contribute to it! I find it quite
interesting. I remember seeing a woman perform on a circus bicycle at the '83
(?) National Unicycle Meet. I was very impressed with her skills and routine.
Since then, I haven’t seen anyone ride one (I’ve been away from unicycling
for almost ten years, so that might explain why!). Does anyone here ride one?
Are they more popular in Europe? I’m planning to attend the NUC next week,
and I’m really looking forward to seeing friends and learning new things
about the sport!
             Stayin' on top,
             (more or less!)
                 Dan Whalen
EAA26712 for <UNICYCLING@WINTERNET.COM>; Wed, 19 Jul 1995 04:32:55 -0500
Posted-Date: Wed, 19 Jul 1995 04:32:55 -0500 Received-Date: Wed, 19 Jul 1995
04:32:55 -0500 Received: from AUVM.AMERICAN.EDU by AUVM.AMERICAN.EDU (IBM VM
SMTP V2R2) with BSMTP id 6115; Wed, 19 Jul 95 05:31:31 EDT Received: from
V1.2a/1.8a) with BSMTP id 6056; Wed, 19 Jul 1995 05:31:31 -0400 To:
auvm!paladin.american.edu!gatech!news.uoregon.edu!news.dacom.co.kr!
news.netins.net!solaris.cc.vt.edu!swiss.ans.net!prodigy.com!usenet From:
BNEK92A@prodigy.com (Daniel Whalen) Newsgroups: rec.sport.unicycling Subject:
big wheels and penny farthings Date: 19 Jul 1995 06:39:59 GMT Organization:
Prodigy Services Company 1-800-PRODIGY Lines: 12 Distribution: world Message-ID:
<3ui9bv$koq@usenetp1.news.prodigy.com> NNTP-Posting-Host:
Hi, Just an unsolicited opinion… I think big-wheel unicycles and penny
farthings look really awesome! Has anyone heard of The Wheelmen? I saw them
perform on their penny farthings during a televised parade recently. It looked
really neat! I have enjoyed the recent articles posted in this newsgroup about
constructing and riding big wheel unicycles. I would like to own one eventually,
but I’m not experienced with unicycle construction, and the waiting list is very
long at The Unicycle Factory. Oh well, I guess I’ll just have to be patient! Dan
Thank you Dennis, for that wonderful first MUni trail ride story!
Philippe, thanks for the very interesting story about Thierry the MUni expert!
On One Wheel,
Re: My first MUni trail ride (fwd)
Forwarded message:
> From: jhalpern@super.win.or.jp (Jack Halpern) To: d.kathrens@genie.geis.com
> Cc: unicycling (Unicycling mailing list), schecter@tfs.com (Mark Schecter),
> kfuchs@winternet.com (Ken Fuchs), unicycle@aol.com (John Foss),
> ruizb@aol.com (Alberto Ruiz) Date: Thu Jul 20 8:05 JST Subject: Re: My
> first MUni trail ride Reply-To: jhalpern@super.win.or.jp
> know of an approprate introduction, perhaps past posting tothe list or news,
> that couls serve as a basis for an article in UI?
If someone wants to answer the question, “Is there rough terrain unicycling”, or
something similar, I will include it in the FAQ. Also, if someone wants to start
a web page devoted to the topic I will link to it, or include it here at Kent if
you can’t feed web pages from your site.
Beirne
Beirne Konarski | Unicycling Web Page: bkonarsk@mcs.kent.edu |
http://nimitz.mcs.kent.edu/~bkonarsk/ Kent State University | “Untouched by
Scandal” |
