Just did my first real muni ride. First impression, this is the greatest
sport the face of this earth has ever seen!! Dispite the fact that i was
doing it on my piece’o’crap 28 spoke schwin 24, i had the best time i have
ever had doing anything! within maybe 20 min we went from 10 tryes for lines
like, 2 roots, over a small log, down 1 ft steep grade and then through the
pile of rocks, to 1 try for: down that 14ft 50 degree slope full of nothing
but huge rocks and roots-through the river at the bottom-… Lots of fun,
not much pain. exactly the right amount of difficulty, but plenty of room to
grow in that same area. the only real pain i expirienced was in griping the
torker seet taht was the only one left with a grip taht i had not destroyed
already. It is actualy hurting very much to type right now because of that.
you had to kinda, lock your fingers inside the slot provided under the
saddle, and grip your palm and your thumb firmly around the nose of the
saddle. this left no room for a person on the seat whatsoever, and had to be
done from the mount or you were never going to be able to grip it later. My
little bros pashly with the “horrible” viscount seat was sooooooooooooo much
better. i would have traded my left balence arm to have had his seat.
anyway, im planing on building a handle on the schwin seat using an old seat
post cut off about 1 1/2" from the braket, and an old road bike stem. simply
drill new holes in the front of the seat frame, attach the braket just like
if you were attaching it in the normal place, and tighten the stem where it
would normaly hold the handlebars to the seat post, use some duct tape along
with some sanding to patch up the rough edges, and you have a nice little
handlebar. and i have to say, out off all the seats i have used, including
the myata air seat conversion, my schwin is the most comfortable. Just
unusable for the moment for lack of any place to grip. ill report back with
how the handle instalation works. if it works, its a fairly easy prosses
using parts most people have lying around in the garauge.
__
trevor andersen
