MY FIRST BABY!!! (and some problems too, plz help)
its a torker!! (sorry if i made u think i was having a kid, im only 13:) )
its a 20’ LX jet black, ive ridden about 5 or six hours and i can already: free mount, hop 3 inches, ride half a block, and go down a slightly steep hill
only things im having problems with are: unicycle makes clicking noise after every revolution or tire, on the crank wheel there’s a plastic circular thing that keeps falling off, and its seems a little difficult to jump (this may be because the tire is to full of air or my seat post is to high???)
anyway, just wanted to let u all kno that i have a uni now!!
if u kno anyway to fix those probelems plz help, Thx
Are you male or female?
lol, male. u kno how to solve uni problems tho??
I thought you were. Been to a psychologist lately?
God Ivan, you crack me up :smiley:
Have you checked the cranks and pedals to be sure they are tight? Is the “plastic circular thing” like the hub cover or hub cap?
Loose cranks and loose pedals are bad things because they are easily damaged when loose. Remember, the left pedal is threaded backwards from standard threads.
While you are at it, check all the nuts and bolts. Bearing caps should be snug but not real tight. Check under the seat too.
