My dilemma.
I seem to be heading in the direction of trials. I have a United Extra Large Adult Trainer with Euro 150s and it has really held up well to what I have thrown at it. Mostly hopping, hopping up and down stairs, riding down stairs, crank grabs and even some Muni. I landed a 15" drop once too (that’s a lot for me). The problem is, I would really like to try some more hardcore tricks. I would like to learn hopping seat-out to get me some extra height to work with. However, I’m not sure how much that hub and 2.125" wide street tire can handle. I’m 215 poundsand I can easily fold it over on a big side hop. How much stress can this setup handle. Has anyone run this setup before? Should I start upgrading or just sell it and get a real trials cycle? Money is an object and I just want to make the right decision here.
Also, is the Nimbus trials really a good deal at $169?
Anybody??
Re: My dilemma.
For the stuff you are doing it is perfect. It will probably last you a good year or so, even with progressions to higher drops. Its definetely well worth the money, but buy some Bike euros for it or some nimbus-x’s(like 25-30 bucks) cause that cranks bent on me(down and rotated sideways) after just dropping of a park table like maybe 20 times(in addition to other drops and ridage).
Its good but the cranks are like are butter. You should see if you can get a splined hub and cranks. You’ll probly start off easy but you’ll likelly do bigger drops and jumps. The onza is a very good buy.
Re: Re: My dilemma.
Which part of it will last a year? The cranks? Or the hub? That Onza is mighty tempting, but it’s a bit out of my price range. And are there any 24" trials cycles? Or do you just have to use a Muni, like the KH24?
Re: Re: Re: My dilemma.
The hub should last as long as you don’t do anything too crazy. Just make sure that when you land, you roll out and land square to minimize the stress on the cycle. The cranks might not last too long, but they are cheap.
Normally 24 inchers aren’t called Trials cycles, but a MUni is basically a large trials cycle. Or, you could say that a trials cycle is a 20 inch MUni. The main difference is that the 24 will be heavier but faster and a bit more practical. By practical I mean that you can cover some distance on it.
Hope that helps.
Daniel
