I was in the same position with my old Schwinn (cottered cranks, s-7,
etc) and I just replaced the wheel and cranks with new ones from Schwinn.
I think it cost around US$50 or so. The new wheel isn’t particularly
strong or light (it has a single-wall steel rim), but it’ll at least hold
a 2.6" tire. I haven’t tried anything wider; the frame would fit a 3"
tire, I’m sure, but I don’t think the rim is quite wide enough for that
large of a tire.
Anyway, the setup was all right; now it’s my son’s muni, with a 2.1" tire
currently (he didn’t like the squishy 2.6). I’m too big and fat (6’1" &
220 lbs) for that uni (it took a lot of maintenance), but not for my
Telford (which only asks for the occasional wash and polish).
Peter Kittle English Education Adviser Department of English CSU, Chico
Chico CA 95929-0830 ph: 530/898-5305 fax: 530/898-4450 email:
pkittle@csuchico.edu www: http://www.csuchico.edu/~pkittle
> From: Jeff Lutkus Reply To: Jeff Lutkus Sent: Friday, April 20, 2001
> 10:49 AM To: unicycling@winternet.com Subject: Re: muni suggestions
> Yeah… my Schwinn has been good to me… I basically learned to ride on
> it, and now only use it for things I’d be afraid of breaking my good uni
> on. I was just thinking about going for a whole new uni… but if I
> could get some more life out of the Schwinn frame, I’d consider
> replacing the wheel. Does anyone know what the largest (and fattest)
> tire a 24" schwinn frame can fit?
> jl
> — John Hooten <jhooten@rcsis.com>
> > wrote: It’s too bad about the S-7 rim. Your tire options are definetly
> > limited.
> Replacements for cottered cranks are pretty limited as well. I replaced
> my old Schwinn S-7 rim and cottered crank hub with a Montey wheel setup.
> >A 24 X 3 tire won’t fit in a Pashley frame. For that matter a 26 X 2.65
> Gazzolodi just barely fits. The wider tires definitely lets you ride
> through more difficult terrain, but they had not yet been used when the
> Pashley Muni came out. That’s one of the Pashley’s biggest drawbacks. If
> you want to keep open the option of a really wide tire you will need a
> different frame. Doing it
> >for under $500 could be a challenge. I think a 24 X 3 tire would
> >fit in a
> 26" Semcycle Deluxe frame. It may even fit in a 26" United frame. At
> Muni weekend Chris Reeder was riding a machine with a Profile hub on
> what looked like a United frame with upgraded bearing mounts welded on.
> You could investigate this or builing (or having built) your own frame.
> >Good Luck,
> >John Hooten
> >Jeff Lutkus wrote:
> >> I tend to think upgrading my Schwinn would not necessarily be worth
> it… I’ve got a 20+ year old 24" I found on e-bay… The S-7 rim will
> not let me simply replace the tire… realistically, I’d end up
> getting a whole new wheel.
> >> So, if I’m going for a totally new uni, I’d probably want to go
> >> for one
> that I can easily upgrade the tire, or even wheel.
> >> Can I realistically compare a 24x3 tire to a 26x2.6, or does the
> >> change
> in diameter make this totally different? If I were to go with the
> pashley, would I be disappointed later on if I wanted to upgrade to a
> wider tire?
> >> Too bad I can’t just go to my local cycle shop and try a few out.
> >> good day,
> >> jeff lutkus
> >> > wrote:
> >> >Jeff,
> >> >The least expensive starting point would be to get a Kenda 24 X 2.6
> tire for your Schwinn. It is fairly fat and inexpensive. You can get
> one from Unicyclesource. This option has a quite a few disadvantages,
> but it will get you started while you decide where you would like to go
> with this.
> >> >I would like to remind you that the most important thing is the
> >> >rider.
> The best unicycle in the world won’t make me Kris Holm; and Kris could
> ride circles around most riders on a 24" Schwinn with a Kenda tire (not
> that he would ride one). In UNiVERsE it sure looks like Dan Heaton is
> riding a plain, old, heavy Pashley Muni on the North Shore, and riding
> it quite well. That
> >> >said, a good machine will help you to become a better rider. And, I
> agree with Chris Reeder that the important thing is the wheel. The Power
> Pashley from Unicyclesource
> >http://www.unicyclesource.com/Pashley_Cycles_of_England_(4_models)-
> >21323.h
> tml
> >> >comes with a Kovachi wheel with a Suzue Hub and a Sun Mammoth 26
> >> >x 2.0
> double-walled alloy rim. At $390 it isn’t exactly cheap, but it’s a
> pretty good machine.
> >> >John Hooten
> >> >P.S. I don’t work for Unicycle source, or profit in any way from any
> sales made by the Unicyclesource.
> >> >JH
> >> >Jeff Lutkus wrote:
> >> >> All right, spring is approaching, I know it. (It barely even
> >> >> snowed
> yesterday here in Rochester.)
> >> >> I know I’m going to be wanting to find some trails to ride on
> >> >> again
> soon. Last year, I played in the woods on my 24" schwinn. That was fun,
> but I think I could go for something a little better now… so, what
> have people to say about the choices?
> >> >> Based on my experience, I definintely need a 24" or larger wheel
> >> >> to
> be happy. Everyone talks about the fat tires these days. How fat
> should I go?
> >> >> Being that I have little experience in muni riding now, would it
> >> >> be
> reasonable for me to get something with a decent frame, but less
> expensive wheel, then later upgrading the wheel once I realize what I’ve
> been missing? (I might be able to justify spending something in the $500
> range, but it’ll be a while before I can rationalize spending over a
> grand on a single unicycle)
> >> >> Oh yes, looking at Wilder, can people tell me, are there
> >> >> advantages
> to Aluminum besides weight?
> >> >> thanks,
> >> >> jeff lutkus
> >> >> _____________________________________________________________
> >> >> Free e-Mail and Webspace - http://Unicyclist.com
