muni picture
Hi everyone,
If anyone’s interested, I found a website with some pictures of a race I was in
in February. There’s some mountain bike shots and one MUni picture. The address
is: <www.internetstore.bc.ca/slobin> Click on “North Shore indoor mountain bike
challenge” to get to the pictures.
Cheers,
Kris.
Kris Holm, B.Sc. Geologist, Forestry Group, EBA Engineering Consultants Ltd.
Suite 550, Sun Life Plaza, 1100 Melville Street, Vancouver, B.C. V6E 4A6
Tel:(604) 685-0275 Fax:(604) 684-6241 Email: kholm@eba.ca
RE: muni picture
> in in February. There’s some mountain bike shots and one MUni picture. The
> address is: http://www.internetstore.bc.ca/slobin Click on "North Shore indoor
> mountain bike challenge" to get to the pictures.
Kris (in his modesty?) didn’t mention the picture of him was of him leaping off
an 8 foot high platform! Did he successfully ride away? Or break another axle?
In any case you must check it out!
Stay on top,
John Foss, the Uni-Cyclone http://www.unicycling.com
RE: Muni Picture
Nice pic! I was curious about the model of your muni. Obviously it’s
strong. Is it a home brew or commercial, and also, 24" or 26"?
 s-
 Kris Holm wrote:
   Hi,
   Actually, the 8 feet mentioned in the website is an exageration- it's
   probably closer to 5 feet vertical.
   I landed, road a few feet, and then skidded out and wiped on the gravel,
   but the axle survived fine on this as well as the rest of the course (it
   has since broken though). Several mountain bikers (6 or 7 of them) broke
   their bottom brackets on this drop so I was quite pleased that my axle
   didn't break.
   Cheers,
   Kris.
>> I was in in February. There’s some mountain bike shots and one MUni
>> picture. The address is: http://www.internetstore.bc.ca/slobin Click
>> on “North Shore indoor mountain bike challenge” to get to
the
>> pictures.
leaping
>off an 8 foot high platform! Did he successfully ride away? Or
break another
>axle? In any case you must check it out!
>Stay on top,
_______________________________________________________
   Ltd. Suite 550, Sun Life Plaza, 1100 Melville Street, Vancouver, B.C. V6E
   4A6 Tel:(604) 685-0275 Fax:(604) 684-6241 Email: kholm@eba.ca
RE: Muni Picture
Whenever I’m tempted to think I’m pretty good on my uni, I’ll look at this
picture. That’s suicide!
hugh
> From: Stephen.Bankston@merrick.com Reply To: Stephen.Bankston@merrick.com
> Sent: Friday, April 9, 1999 2:16 PM To: unicycling@winternet.com Subject: RE:
> Muni Picture
> s-
> Kris Holm wrote:
> Hi,
> Actually, the 8 feet mentioned in the website is an exageration- it’s
> gravel, but the axle survived fine on this as well as the rest of the
> course (it has since broken though). Several mountain bikers (6 or 7 of
> them)
> broke their bottom brackets on this drop so I was quite pleased that my
> axle didn’t break.
> Cheers,
> Kris.
> >> race I was in in February. There’s some mountain bike shots and one
> >> MUni picture. The address is: http://www.internetstore.bc.ca/slobin
> >> Click on “North Shore indoor mountain bike challenge” to get to
> the
> >> pictures.
> him leaping
> break another
> >Stay on top,
> V6E 4A6 Tel604) 685-0275 Fax604) 684-6241 Email: kholm@eba.ca
RE: Muni Picture
> It also has a seatpost shock and V-brake.
What in the world is the v-brake for?
I can understand using a drag brake if you were on a touring uni going down a
mountain pass. But a brake on a muni with 175mm cranks?
Are you bombing straight down some nasty steep slopes?
John “I never break” Childs john_childs@hotmail.com
> It’s a home-brew, made by a machinist in town that makes bike prototypes.
> In short, the frame is 4130 CrMo with Miyata style bearing casings, the axle
> is a 20mm 8 spline 4130 CrMo BMX axle braised into a one-piece custom 4140
> steel hub, the crank arms are 175mm, the rim is a 26" Mavic SUP 36 hole
> downhill Mtn Bike rim, and the tire is a 26"x2.35" Kujo downhill mtn bike tire
> with foam- reinforced sidewalls (which prevents pinch-flats). It also has a
> Cheers,
> Kris.
Get Free Email and Do More On The Web. Visit http://www.msn.com
Re: muni picture
The 2-wheel guys call that “Getting some air”
> The address is: <www.internetstore.bc.ca/slobin> Click on "North Shore indoor
RE: Muni Picture
Hi,
In short, the frame is 4130 CrMo with Miyata style bearing casings, the axle is
a 20mm 8 spline 4130 CrMo BMX axle braised into a one-piece custom 4140 steel
hub, the crank arms are 175mm, the rim is a 26" Mavic SUP 36 hole downhill Mtn
Bike rim, and the tire is a 26"x2.35" Kujo downhill mtn bike tire with
foam-reinforced sidewalls (which prevents pinch-flats). It also has a seatpost
shock and V-brake.
Cheers,
Kris.
> s-
> Kris Holm wrote:
> Hi,
> didn’t break.
> Cheers,
> Kris.
> the
> >> pictures.
> leaping
> break another
> >Stay on top,
RE: muni picture
Hi,
Actually, the 8 feet mentioned in the website is an exageration- it’s probably
I landed, road a few feet, and then skidded out and wiped on the gravel, but the
axle survived fine on this as well as the rest of the course (it has since
broken though). Several mountain bikers (6 or 7 of them) broke their bottom
brackets on this drop so I was quite pleased that my axle didn’t break.
Cheers,
Kris.
>> indoor mountain bike challenge" to get to the pictures.
>Stay on top,
