Muni Cycle
My 24in torker got bent up. I’m now looking for a cheap/decent 24in unicycle under $200 that should be fairly durable. I was checking out the BY907B!
Does anyone have some feedback on this unicycle. I would very much appreciate it. Thanks
What bent on the Torker? I’m asking because I would go for a unicycle that uses a stronger version of that component if you want to avoid the same thing happening again. If you could stretch your budget to a Torker DX or Nimbus you won’t have to worry about breaking your unicycle any time soon.
That Summit is about the same quality as your Torker but with a larger tire. It’ll hold up for basic riding off-road provided you don’t do much hopping and dropping.
That Summit is about the same quality as your Torker but with a larger tire. It should hold up to basic riding off-road provided you don’t do much hopping and dropping.
What bent on the Torker? I’m asking because I would go for a unicycle that uses a stronger version of that component if you want to avoid the same thing happening again. If you could stretch your budget to a Torker DX (another $80) or Nimbus (+$100) you won’t have to worry about breaking your unicycle any time soon.
By907b
Thanks a lot! The reason my torker wheel bent had nothing to do with unicycling. My little brother accidentally ran it over with a concrete filled car tire. :frowning: It was a good uni (my old one was a Torker Unistar LX 24") not super fancy but I don’t want to spend hundreds of dollars. I just bought a Nimbus trials for $300 and I don’t want to spend much more money right now. I like the large tire on the by907b; so if you could compaire my old one with (the Unistar) with the by907b and give me some feedback that would be great! Thanks, Unicalf
