Mounting an HS33 on a T7
I just broke the lever casing on my HS33 after a lame-o upd.
Two questions:
  1. Since I need to buy a new lever, any suggestions on an alternative?
  2. Where do you mount your lever on the T7. I thought I had the lever clear of danger, but it hit a rock at just the right (i.e. wrong) angle. I really like having the lever under the seat, but that doesn’t seem possible with maggies AND a T7.
I’ve attached a poor quality photo of the breakage.
(The white line is the crack)
Let me know if you find new housings for cheap. I’ve broken 2 or three of them on muni’s.
On tip: mount it slightly loose, so hard impacts move it aside instead of breaking it :slight_smile:
corbin
This is the pro tip!
I’ve got the jankiest break setup on my Coker; it’s an old cable brake from a rusty ten-speed held onto my handle with some water heater strapping and a stripped bolt.
This setup has survived over 1000k of road riding and a few offroad rides as well, with many UPDs therein… all because it sits loosely on my handle.
Don’t tighten those handlebar clamps, kiddies!
