Alright, so here’s the deal. I want the A T 7 handle. I have the standard issue KH seat post. I would like to know all the parts I will need in order to get this handle to work. Posting the links would be much appreciated.
Thanks in advance,
Chase
Thanks in advance,
Chase
You’ll require a rail type seatpost (bike style post) in the correct diameter to fit your frame.
I am assuming you mean one like this.
http://www.unicycle.com/shopping/shopexd.asp?id=602
I was looking at this one. I am not exactly sure the diameter of the coker seat post tube.
I think it is something like 22.2 mm. Is this correct?
Chase
Yes a stock Coker is 22.2. A primo works nicely, and cheap too.
So is that all I will need for it? Just simply the primo post?
Chase
[threadjack]
[title]
Hello World
[/title]
[body]
Do you all think an AT7 would be worth it on my Nimbus 29er?
Thanks.
[/body]
[/threadjack]
NO, the primo post does not fit to the T7. I ordered the Primo and neither of the adapters matched the spacing of the T7 rails. The post diameter is correct however. I’d get the KH rail post.
FMF make a lightweight and strong aluminium rail-type seatpost in 22.2mm diameter. Bedford unicycles is where I got mine. They also come in sexy carbon fibre!
Wierd, I woulkd have thought they’d make the spacing standard, but apparently not. The KH won’t fit, it works great on my nimbus frame but is too large a diametre for a coker frame. I’d go with tony’s advice.
Well, the Primo didn’t fit my T7 rails, maybe I could have forced it, but I didn’t. It is close to fitting, could be a tolerance problem. I haven’t tried another rail post adapter, since I ended up using a std bolted seat post.
