monty trials uni
Does anyone know anything about the new Monty trials uni?
I’ve just bought the qu-ax yellow hub but the monty was way cheaper.
It’s from a bike trials brand, it should be good… or not?
The monty isnt that great… the hub is non splined… the rim is OK but if I was you i’d go with an alex32…So the hub and cranks are pretty weak and will bend pretty easelly… if your gonna be doing drops and stairs yur better off with your qu-ax.
The frame also is very bad, it looks like the old big blue qu-ax frame which weights 100kg, and always hurts you knees.
