monty rims
hey man,
ive been riding with monty rims on my trials bike and my trials unicycle without fuss for the past three years, i still have the original rim on the bike, with a few little dents in the sidewall.
How did i do this? well, first off i built the wheel three cross, strong, stainless nipples, high tension. then i make sure i check the tension every few rides.
Most trials bikers will tell you they have had no problems with the monty rims, theyre among the strongest rims out there. and only break when,
Tension in the spokes is not even, leading to excess pressure on one part of the rim, or
too low tyre pressure, resulting in bottoming the tyre on the rim, leading to excess pressure and breakage etc.
If you had a few spokes loose, chance is the wheel was in need of attention, which was why it broke, take care of your wheels and they last ages, you wont find a stronger mod trials rim!
Ive pulled of many 4 foot uni drops and over 10 foot bike drops on the rims with no probs, most probs with my cranks though.
As for other rims which fit the monty mod tyre,
Alex dx32
arrow mod rim,
Thats it!
you can lever a monty tyre onto a normal rim with metal tyre levers, but you lose air space in the tyre and youll never get it back on!
Hope ive helped. and yes, you can see the seam on monty rims, theyve always been like this!
