is it true that 14 gauge spoke nipples pull through the holes on a Monty rim because they are to wide?
All’s i know is i had a monty wheel and the nips puled thure
Re: Monty rim nipple holes?
Hi,
you need thicker nipples for Monty rims!
Roland
Yes. You can use wider nipples or brass washers under the 14g.
