Can a Stealth Torker frame accommodate a 2.5 inch Monty Tire?
I tried searching the forum but couldn’t find an answer.
Thanks,
Daniel
Thanks,
Daniel
no way!
the monty 2.5 is about as fat as a Gazz tyre.
the best you’ll manage in that frame is a maxis maxx daddy tire.
its not as good as a monty/onza, but if you feel the overwheming need for a knobly tire without changing your frame/wheel it may be your only option.
consider yourself lucky though decent trials unis are much cheaper than they where when i got mine.
Re: Monty on a Stealth?
the monty tyre needs a different rim diameter to normal 20" tyres too, so you’d need a different wheel anyway.
Joe
