So today, I was just trying to give my MUni a little clean up. I removed the pedals but then the insert on the moments also come out with it. Can anyone tell me how to fix this? or should I use the warranty? or should I go to a bike shop and get it repaired?
The first two pics are how they SHOULD look
the next two are what came outâŚ
from the look of it, you just need to screw it back in and tighten it down. Youâd need one of those tools you used to take cranks off way back when : P they go in those holes and you just turn it like any other tool. . . well. . . I guess youâd need two of them in this case. Your local bike co-op should have them, or you could just send them back O:-)
would it be easier (and cheaper) to let the bike shop do it? or would it be a better investment to buy the tools and do it myself incase this happens again?
I would get the tool and do it yourself. Than you are ready for the next time this happens. Why pay someone else a ton of money to do something that you can do for really cheap? Thats the way I look at it.
I think I have also heard of people using a peice of wood with a nail through it for this job too⌠Not positive though.
one time it happened to me, as i was unscrewing a pedal i could see the insert spinning. so i just tightened the pedal as hard as a possibly could (more than i normally do) which tightened the insert. i may have just been lucky, but after that the pedal came out without the insert spinning, and again back in with no prob and still rides fine.
I did it and I dont have problemes with my cranks inserts anymore.
Put your insert back in it, throw some superglue(DO NOT PUT GLUE ON THE PEDALS) and let it dry a few minutes, then you can put the âInsert boltâ back on it and it should be okay.
Hereâs the tool you can built⌠http://www.unicyclist.com/forums/sho...0&postcount=25
so just super glue the whole insert in? the super glue goes on the TREAD of the insert right? I just donât want to put the glue then see that I glued it wrongâŚ
yep, on the insert thread. I suggest to put the insert and then put the glue, because it might dry really fast and maybe you wont be able to get the insert all the way through the crank.
EDIT: I was looking at your picture and thought, my insert didnât came all the way out. I couldnât even get them out
yea, sorry, youâre right. I tend to be weary of the âthis will never come off EVERâ type stuff, so I instinctively went for anything but the red : P but yea, since you really donât want that to come off, redâs probably best.
