PAL (Phase Alternating Line) is a color encoding system used in broadcast television systems in large parts of the world.
NTSC (National Television System Committee) is the analog television broadcast system used in the United States, Canada, Japan, Mexico, the Philippines, South Korea, Taiwan, and some other countries. Television engineers I’ve worked with will tell you that NTSC acronym really stands for Never The Same Color
24p refers to a video format that operates at a true 24 frames per second (or typically, 23.976 frames per second when using equipment based around NTSC frame rates) frame rate with progressive scanning (not interlaced).
It isn’t on your list, but ATSC (Advanced Television Systems Committee) is the digital television broadcast format which will replace the analog NTSC television broadcast system by February 17, 2009 in the United States and August 31, 2011 in Canada.
HDV denotes high definition video. HDV stores 16:9 (that’s the “aspect ratio” - the length of the picture versus the height of the picture - standard definition TV is 4:3) high definition video on DV tapes, supporting both 720p and 1080i (NTSC and PAL).
I presume your making a unicycle video, because this is RSU! oh well, I don’t care
I am currenly using Adobe premire to make my video, its cool software.
I am making mine in DV-NTSC, and there are options of
-standard 32kHz -standard 48kHz- I’m using this one for my video, its ok for me.
-wide screen 32kHz
-wide screen 48kHz- [I]I presume this one would work for you.
[/I]I’m not quite sure what a fire wire does, but surely you can just use a USB and save them to your computer, then import them in to adobe.
I am not an expert though, so don’t take my advice as true fact, just try it!
I’ve heard that the easiest thing to do is capture the video from your camera to your computer using iMovie, then importing those clips into Premiere. I also highly recommend getting a firewire cable. Much faster, much better quality. You can find them for around $15 I think.
i dont have final cut pro
i took a class on final cut pro and Adobe after affects but i cant afford the software and my parents wont let me illegally download it…
does anyone have it on a disk or something the can loan me? ill send the disk back when i finish downloading it. remember i have a mac
does anyone have it on a disk or something they can loan me? ill send the disk back when i finish downloading it.
oh yeah and remember i have a mac
As far as I know. I haven’t used Premiere for 5 years, but I like it when I used ot back in high school. Let’s just say that Window Movie Maker is to iMovie as Premiere is to Final Cut Pro.
I have always felt that it was mainly the operating system that made me choose Macs over Pc’s.
