I wonder if the tire valve being described is the same one that is on my Klepper
kayak trailer. It is a very obscure tire valve that looks like an oversized
Presta. The air pressure alone is what keeps the valve closed–there are no
threads or nut on top as in a Presta valve. I once found a Klepper dealer who
knew the name of the valve–German I think. I will see if I can track it down.
Woods Valve There is a third type of valve, very rarely seen, which has a bottom
similar to a Schrader and necks down to about the size of a Presta. This is a
Woods valve, also known as a “Dunlop” valve. Woods valves were formerly popular
in the British Isles and Asia. These low-tech valves work with rubber tubing and
spit. You can pump them up with a Presta pump.
Is this the valve type that comes on the Miyata?
-Mary
MaxfieldD@aol.com wrote in article <11e7fcb9.245881a0@aol.com>… > I wonder if the tire valve being described is the same one that is on my > Klepper kayak trailer. It is a very obscure tire valve that looks like an
> oversized Presta. The air pressure alone is what keeps the valve closed–there > are no threads or nut on top as in a Presta valve. I once
found > a Klepper dealer who knew the name of the valve–German I think. I will
see > if I can track it down. > > David Maxfield Bainbridge Island
If this is the type then the pumps are common in the UK, my uni uses a woods
valve. Sorry don’t know the make or model of uin.
Bob
hartmame wrote in message <01be9260$cb6a2740$5d788981@davidsfe.rwc.uc.edu>… > >This is also from SheldonBrown’s Page: > >Woods Valve There is a third type of valve, very rarely seen, which has a >bottom similar to a Schrader and necks down to about the size of a Presta. This >is a Woods valve, also known as a “Dunlop” valve. Woods valves were formerly >popular in the British Isles and Asia. These low-tech valves work with rubber >tubing and spit. You can pump them up with a Presta pump. > > Is this the valve type that comes on the Miyata?
