There are many good things about this unicycle, and a few drawbacks.
good things drawbacks
the seat the seat
is a lot more comfortable the base is plastic so the seat
then any other seat I’ve had. could be stronger/ it flexes ifput the front bumper can take a a lot of weight on it
lot of contact with the ground
before it wears out.
the seat post adjuster most likely you’ll need
quick release with groves seat post extension
so you can tighten or loosen ‘cos its pretty short
with a tool/spanner having two quick releases is
not recommended can hurt
the frame the frame
seems to be strong.
has flat crowns good not a lot of clearance
for one foot/standup for fat or buckled tires
/gliding skills.
it’s got a quality join
to the wheel
the wheel the wheel
has a smooth rotation the wheel gets untrue very
making everything nice Easily not really for jumping
about a lot
the peddles
are of white none marking
plastic variety, I haven’t n/a
had any grip problems
the cranks
are of the short variety
(took a bit of getting used
to but I like them better n/a
now).
it’s a cheap,(in more ways then one) quality unicycle.
well I like it. I’ve had it for just over one year
I reckon your looking at a 8.3 out of 10
