Well, you certainly have the skills to pay the bills: Last one to get off your device and on your unicycle wins (Bragging recommended) - #147 by SirCranky
I am glad to see that the 45s are back in business!
Just went for a quick 9 km test ride with an average speed of only 13.1 km/h due to the up- and downhills, some of which had to be walked. The best (flat) segment was 21.7 km/h over 0.72 km. A believable top speed from Strava is approximately 26 km/h.
The cranks were shimmed with a single strip of patent band (?) on each side and I experienced zero issues in that regard.
Crank Length?
If the bench is a regular size, then this uni is probably a 10” wheel with 20mm cranks! ![]()
…and a 57mm brake disk. (just a wild guess)
so cute ![]()
No, more like a 7mm disc brake.
24"/45 mm flat 10 km test: 29:23 (20,4 km/h)
Strava
10 km on 45mm cranks, averaging 20 kph! ![]()
Congratulations
Somehow this amazing feat doesn’t surprise me, but I have SO many questions…
This is a considerably higher gain ratio than 36"/75mm. Are there at all any actual advantages with 24"/45mm? You are already way faster on 36"/100mm.
How is it to ride this setup over a 10k? It must be super smooth and exhausting. Everything must surely be perfectly executed.
How do you even stop this silly machine?
Braking was hard enough on 16"/45mm tbh.
Are the shims and cranks still holding? You are really pushing these cranks beyond the limits ![]()
We obviously have to make an other attempt with 36"/45mm next time you are in Oslo…
(Also, this is currently the only cortorless/45mm compatible uni I have now…)
I have been thinking about it! A freewheel 36"/45mm uni would be sooooo fun ![]()
Come on, with a 33% smaller uni he’s just about 33% faster than I am on my 36er - why make such a fuss about it? Ts, ts.
I mean, we’re talking about SirCranky…
The only advantage is the fun challenge. 24"/75mm is almost certainly faster, even on the flats.
10 km really is no issue on such a flat course.
As for stopping, I don’t. Even on a slight downhill it is almost hopeless. A setup with brakes could actually be viable for actual rides provided the uphills Arent too steep.
Both the cranks and the shims seem to be holding up perfectly.
Coincidentally I am already here and am open for a proper 36"/45mm test next week. I leave on Saturday.
You are in town?!
(Un?)fortunately I don’t have the Beast ATM. It is on loan actually. But in all seriousness it makes a lot more sense (or a lot less NOT sense at all?) to try out 29/45mm.
Did you even bring your 45s?
Of course i have the 45s!
Yesterday I had the opportunity to ride Syoten micro machine. It was easy to coast, but hard to get enough speed to start a good coast. I also did some 180 uni spins.
Craziest part about the experience. After getting used to that uni, my 20” with 89mm cranks which had been the smaller cranks I had rode until yesterday feels now like a monster unicycle ( like when you ride a 29” 137mm cranks for the first time, actually more like I imagine 150mm cranks).
I’m impressed that you were able to ride my 10-inch ultimate wheel after several tries.
Attempting to make tiny cranks for my unicycle accidentally used the wrong left hand tap because I forgot TPI was a measurement. These are aluminum 89mm triad dynasty cranks and I can’t find a thread repair kit for this thread so I want to know if anyone has a left side crank they would like to part with. (Shortened to approximately 31.75mm±1.5mm last picture is the right crank next to a 160mm)
