I have noticed that a couple people i know saw my designs and said “Hey, Those are soooo cool, you should show them to other people”. As i come up with them i will post pics and a little bit about each one.
(these are totaly random designs, There is no goal in them, just for fun)
This is a frame i came up with about a week ago, i have alot of scrap 3/4" Steel tubing, so i tought i would design a frame i can make with the tools and metal i have.
Toe clips on a BC wheel sounds sorts suicidal. I like the idea and design of that treaded uni. I assume the green tread goes all the way up to the hub through the frame right?
I think your designs are cool, and I dont see what the problem with you posting them is. Its really neat, and interesting-
what do you use to make them?
I don’t know what Drew’s problem is. If you can keep your posting relevant and in controlled numbers, there’s nothing wrong with posting your ideas.
I think the designs are very interesting. But that one that I asked about earlier… I think it would be cooler if you made the tread run up to the hub instead of using the belt drive. That belt drive makes it work too much like a giraffe.
