how can i make one? can i use a bmx wheelset w/ 14mm axle? what should i make the plates out of? aluminum, diamond plate, steel?! i don’t know! what are the best parts for a durable bc wheel? also i need stuff that won’t rust easy, cause here in FL, even plastic’ll rust.
Stuff in Florida rusts easy? Do you get heavy snow fall and salted roads?
If you’re going to make your own plates, EB Plates are the only way to go (Weight wise).
Use .065" thickness 3/4" steel tubing. And 1/8" - 1/4" thickness main bracket plate depending on if you plan on doing ridiculous drops on it.
yeah stuff rusts! its the salt air! should i show you my mom’s bike after 2 months?
cut two peices of angle iron and drill the correct diamater holes right in the top
you forgot to mention the step where you bend those pieces of iron into unusability. the only iron strong enough to use for bc plates is so thick it’s hard to work with and too heavy to ride with.
P.S. I’ve notice you’ve stolen a clip of Defect and put it on your myspace, dunawan. Yes, that’s stealing. Defect is copyrighted. Dan Heaton will kick your ass if you don’t take it down right away.
