Make an ultimate wheel out of a unicycle?
I was thinking… is there any reason why I couldn’t just pull the seat off of a unicycle and use it as an ultimate wheel? Also, how do you think the difficulty would differ between a 20 in and a 28 in? Thanks… M@
It will be harder than an ultimate wheel because the pedals, ergo, your feet, will be farther from the center of the wheel, thereby making the wheel flop more. It is possible, though. I’d first reccomend that before you remove the frame, you spend a day working on seat dragging, which is basically the same thing, without the frame removal. It might give you a better idea of how incredibly diffucult yur endeavour will be. Happy riding.
Makes sense… any idea on how difficult a 28 inch would compare to a 20? Thanks.
when it comes to UW’s,the bigger wheel is better since the angle of the wheel bashing into your legs is alot less.
