Magura leak
Greetings,
It appears I have a slight leak coming from the slave cylinder of my Mugura HS-33 brake. I understand that there’s an “olive” on the line which get’s jammed into the pipe and tightened during assembly. Could a leak of this nature mean I simply need to loosen the nut and jam everything in there firmly while I tighten the nut?
The only visible sign of a leak is oily dirt around the brake on the slave side. There’s no dripping and the brake is functioning fine. Thanks everyone.
Cheers,
Jason
The “olive” is actually a “compression fitting” sleeve that goes around the brake tube. Try tightening the line. It will probably compress the ferrule and stop the seepage.
Okay. Do I need to be concerened about over tightening? I don’t plan on cranking on it, I’m just wondering how sensetive it might be.
Jason
You will be compressing a brass collar that goes around the plastic tubing. It is a “compression” fitting, so just snug it up real good. Just use common sense and tighten it the same as you would tighten a small nut of the same size.
Check out the Magura Cult page for all the info you’ll need to maintain your Magura brake.
<http://www.execulink.com/~dtierney/wmc/Magura/contents.htm>
Here is a specific page about fluid leaks:
<http://www.execulink.com/~dtierney/wmc/Magura/geninfo.htm#Hydraulic Fluid leaks.>
There is lots of other info on the Magura Cult page so look around.
You can also download workshop manuals direct from Magura:
<http://www.magura.de/english/frameset/default.htm>
<http://www.magura.de/english/download/downloads.htm>
Hmm… That link got jumbled. I’ll try that one again.
Magura Fluid Leaks
