Magura HS33 - Out of adjustment
Hi, last week I’ve install Magura HS33 on my 26 Muni. It seems that after any UPD the cylinder get out of adjustment :thinking:
I fastened the Bolts pretty tight…
Here’s a pic:
Anyone with/has similar problem?
PM Me and I’ll send you some HS33 brake install and adjustment instructions that I wrote up and send out with the HS33’s I sell to uni riders on here. Its likely an easy fix. Likely your mounting bolts aren’t tight enough or your crossover tube is too short.
Brycer1968
PM sent
hey Brycer, can I put the lever from my maguras onto my avid juicy 3 disc brake caliper?
Interesting idea. . . I haven’t tried that bit of brake lever-swapperey, its unlikely to fit, but let us know if it works.
Brycer
Avid uses DOT fluid, Magura uses mineral oil.
Avid and Magura use a different hose mount and hose, so you’ll need to figure that out.
The Avid also seems to have a larger resevoir than a Magura.
So, maybe a better idea is to cut off the end of the lever on your Avid, the the Spooner will fit fine OR wait until Kris releases a universal spooner :wink:
i want the control of the dial on my maggies, the avid juicy doesn’t have any way to adjust
